MKtrill
this sounds exactly what happend to my mk3 cabinet. Every time i disconnected monitor from power, the game boots plays sounds coin doors, marquee, the works (except for the monitor), AS soon as i plug the monitor back into it, the power supply blows the right fuse Every single time........ people have suggested that it may be a grounding problem, what caused my monitor to go out was believe it or not, but a freaking microswitch happend to touch metal in the control panel, and Zap that was all she wrote. before then i would get shocked when wiping the dust off the monitor, or fooling with the microswitches and buttons. so it must be something to do with a grounding issue. Btw my monitor power cables ground wire was.... omitted from going into the power cable. so basically in the three prong connector, it went white, (blank), black the blank is where the green should have been going im assuming.... my cab does have an iso, and all that stuff. but anyway, ill be keeping an eye on this thread to see how it turns out for you, because it may indeed fix my problem as well.
