The tricks to reducing clogging are:
- Don't use the 1.0mm tip. It really isn't necessary for arcade work. Use a 1.6mm instead, which is far easier to clean, and more forgiving. (And it fits DIP chip pins, as well as the bigger header/interconnect pins, without needing to change tips.) It's the one tip to rule them all.
- Use the supplied silver cleaning pin to ream out the barrel after EVERY session. Oxides will build up inside the barrel from just sitting in the air, with the gun hot. But the trick is to clean them out BEFORE they build up, and you'll go much longer between having to do a full teardown.
- Get yourself a 12" long 1/16" drill bit. This is perfect for cleaning the oxide out of the barrel more fully, when you remove the tip. Again, if you do it regularly, you don't need or want to connect it to a drill (as you *don't* want to snap it off in the barrel. Ask me how I know.) The other trick is to clean it with the gun *hot*, and you can do it with just your fingers, slowly twisting the drill bit, and pulling the powdered oxide out, very easily. You can get the whole barrel clean in a couple of minutes.
I've written about this topic before. I repair boards full time, and have used my 808 every day, 12 hours a day, for years now. So I have maintaining it down to a science:
https://forums.arcade-museum.com/showthread.php?t=436320
