My first side art install! Went well! Marble Madness
Altan
Georgia
I wanted to share the result of my first cabinet side art install. I also want to thank members of KLOV/arcade-museum for all the insight they offer here!
I'm restoring an Atari System 1 Marble Madness. It was time for the side art... I was a little nervous but did a lot of research and felt like I knew what to expect. I settled on the "dry" method.
I started with the right side of the cabinet. I positioned the art very well but ended up with a couple of air bubbles. Nothing terrible, but I was annoyed when I noticed them. One tip: look at the art from different angles while doing the install. I couldn't see the bubbles from my angle during install!! I grade my right side result with a "B". It's pretty good. I don't think average Joe would even notice the imperfections.
I moved on to the left side. I took more care to look for bubbles and went a little slower. It turned out excellent! Very good positioning and no bubbles! I grade the left side as an "A". You can see the results below.
Just wanted to share...
... Altan
(oh, a pic of the grade "B" is on my web site --- if you wanted to see that)
You can take a pin and poke a little hold where the air bubble is and use a card to work it out. You shouldn't notice the pinhole, but it will remove the air from under the artwork. You did a great job!
Thanks for the kind words, everyone.
I'll try the pin trick a little... it would be nice to have a very sharp needle that is very small...
... Altan
... Altan
The flat tip of a new blade of an x-acto knife worked better for me than a pin. You can see where the pin was; you can't see the result from the x-acto knife.
Great job, btw!
Addition to the pin prick method....attempt to push the bubble to where there is a line or detail in the art. Make the pin prick right on the line/detail and it will blend right in. You'll never know it was there. I've even used a razor blade and made tiny slits along line where the bubble is and you can't see the slit at al because it's right on a line(where one color meets another).
That looks really nice!
Was this the Phoenix Arcade reproduction sideart? I recently did my Roadblasters cabinet. While it is nowhere as nice as yours, it really made the cabinet look completely different (in a good way). The art I had was NOS so it lost it's 'stickiness' in some areas, but I will be fixing that soon (I hope).
Here's mine (which loks not so great compared to yours, LOL) http://forums.arcade-museum.com/showthread.php?t=161697
Chris
Demogo, Shirkle, thanks for the advice regarding the bubbles.
Chris, yes. The art was from Phoenix Arcade. Very pleased with their product. And... your cab is nice also!
... Altan
