My first Pin! Street Fighter 2 =) FAQs!!
wmacmonagle
Donor 2012
Rosamond, California
I had noticed there is Rubber Kits all over ebays. Are they any good? or I should buy specific seller with high quality. I am leaning to buy from this seller.
http://cgi.ebay.com/1993-Gottlieb-S...0?pt=LH_DefaultDomain_210&hash=item20b59ce84a
I picked this because this has black rubber for flipper. If anyone object. Please say it faster! I ll buy this item today if nobody objects but entertain the 2 cents
Thanks in advance!
Great Seller
I have purchased a few times from this seller before and have had no problems fast shipping and offers discounts on multiple items.Mike
Rubber kits are a rip-off.
Figure out what you need from the machine as the manual is usually wrong and then buy the rubbers here:
http://www.pinballlife.com/
Best prices, fast service, and you can get almost twice as many rubbers for the same price. Also you can pick the colors that you want. Can't beat them.
Awesome, this was my first pin as well. Fun game with plenty of different shots! I'd like to pick one up again someday for cheap. Not a lot of flow but some modes can get pretty exciting.
Thanks in advance!
Reset High Score Save
I wanted to reset the High score save. It has old save from previous owner. I had tried to find a way to reset. I had hit Test mode and see 1-75 features. I hit reset every ones.. and still have old high score save?? it says DAD, MOM, BPS, etc Im getting sick of em !!
LMK and thanks in advance
I think if you remove the batteries from the backbox it will reset everything back to factory defaults such as scores. It might also be a good idea to check them and replace them if you haven't already. Battery leakage can cause corrosion and all sorts of PCB problems down the road. I'm glad I checked the ones in my DM by the previous owner which expired in 2008 but got lucky no leaking.
battery.. okay.. ill try find em.. oh it s in back box. .i see it in google.. thanks
wow i see many important informaiton in it.
i noticed it saidsomethign about having 2 AA battery isntead of 4.. ill check if mine has 4 or two..
also ill need to replace quarter batttery also??? if so .. time to go to radio shacky!
Eventually, you will need some of the info here:
http://www.pinrepair.com/sys3/index.htm
The manual should tell you how to reset all of the scores and make difficulty adjustments etc.
I can send you a PDF of the manual if you dont already have one. PM me your email address if you need a copy.
