I did 5 CRTs today with my BK467. They all used the CR23 adapter and 6.3V for the heater. One CRT appeared dead, but came back to life after running a Restore on all 3 guns!
John
John
Last night I shot a K7000 19" with the rejuv and got all guns to read in the green. I knew all the colors were weak cause it was dim and needed turning up to get it to balence out. The tube had some vert shooter burn in it but it's a game out on route.
So after rejuv the monitor was so red that I couldn't read anything. I thought I had broken something. I had only ran the rejuv on it and then balenced.
After some neck board color adjusting, it has all strong colors. I have to work on it a little more as it looks a but saturated now to me. Good thing that the the monitor works fine now. There's a leak that shows but we'll see if the tube will go out long term. I had picked this one up in the Fresno fire sale for just $30 and capped it. Now it works pretty good in a SF2.
Although I was showing Eseyo1 how the rejuv works and showing him how I do my solder projects we have to give a big thanks to Oryk Z. Your CR31 instructions helped me make the BK CR31 neck board adaptor. It works great now
How did you take those photos? They look really good. Mine always tend to wash out because of flash or get blurry if none used.
ok. pardon my ignorance.
what is a rejuvenation? can it be done with monitor in the cabinet? Or does it need removed?
Anybody know someone in the ohio area that can do this?
I have an afterburner 2 cockpit that I am restoring.
Jesus christ, you guys are lucky. Two monitors out of my 5 cabs would need some tweaking (the green is way too strong on my super chase cab), and I have no idea what to do, or where to find someone who can fix them.
This is voodoo magic to me.
First find a game that puts out a standard monitor test pattern. Once you have the grid for centering and the color bars, it gets pretty easy.
Yeah I had great results on the Matsushita in my Pole Position. Two guns were dead and one nearly dead, but my 470 brought them back. Has a pretty nice picture now.I did a Matsushita in a PP cab and it went from being dark and dim to bright and vibrant. Just beware that your results may vary. A tube might look beautiful but not last long. Just enjoy the time you get out of it.
RJ
It was the heater light and it was pretty light.
ummmm how bad is that? my understanding is that leakage is not fixable.
Am I correct in assuming that a monitor that has had it's tube previously replaced with that from an old TV can be rejuvenated witht he same adaptor, and that the adaptors are "chassis dependent"?
And is it easy to get needed adaptors for a rejuventor such as the B & K?
Thanks.
Darren Harris
Staten Island, New York.
