my california speed keeps loosing gas
cointech
Donor 3 years: 2018-2019, 2024
Arlington, Texas
its a dedicated sitdown and after a while (days/week)
the gas pedal will stop working during game play.
But while you are waiting for the game to start a race during countdown
if you kit the gas, the tac on screen shows the gas is working.
Then when the game starts, no gas.
Also in test it looks fine. If you re calibrate it, it works fine for a while.
I have changed the battery on the cpu and re calibrated.
what is the fix
I had the same problem. Replaced the pot on the gas and fixed the problem. If you check it in the diagnostics the values are always changing which is why you need to recalibrate.
I have replaced the gas pot and no luck
then in test it looks like the break pot was floating a little so
I have replaced that pot too.
Worked fine for about 3 days and now it has quite again.
help
