MultiVector "kit" interest check
I believe the spinners that have PS2 interfaces will be seen as a mouse in
DOS. You would just need to get the appropriate dos mouse drivers.
I think the turbotwist support ps2.
I think you are correct. I think I have one (will check it tonight). HOwever, they would not fit in the mounting posts unless an adapter was created...
The turbo twist just needs a simple hole, no mounting points needed. It might be to deep for that part of the panel with the counter weight. I'll check tonight.
What are you using in yours?
It probably will not fit now that i think of it... I am using an Oscar control spinner (Tempest copy) and I had to shave some of the wood down to make it fit.
Need these spinners repro'ed (and not by RAM controls).
I guess a usb spinner wouldnt work with dos? hmm..
There are USB drivers for DOS. I remember running across them many years ago and being surprised. I may still have them floating around somewhere.
Scott C.
Wow, this is an old thread!
Any updates? Still no artwork and the Linux version is incomplete.
Windows version seems dead too.
I have collected most of the parts to build a multi vector but the software issues I think will be the real problem
I would be in for a harness and maybe some other parts to make it easier
