rmackie6661
OK got a question for everyone, Maybe you've run into this. SO I'm building a 60-1 multicade cocktail and the guys wants a LCD monitor. No problem. I get a multisync vga input monitor and go to test it, to set up the screen prior to install. I cannot get the screen to fit the entire area. it won't center horizontally. ( no mattter what I try in the menu setting) So I try a different 60-1 pcb( same thing). Then I try a old 48-1 and the damn thing works great all centered and works perfect.
So is there anything about the 60-1's that are different for the sync signal. They work fine with the older CRT computer monitors but these newer LCD's just don't seem to work. I had the same issues with two now.
Ross.
Ross.
