Just wanted to say, I finally got around to prepping this same CP for an overlay, and only 80% of my studs were depressed. 2 stuck up above the surface, and one was flush. I tried to use a punch to depress the 2 heads that were sticking up. One worked out OK, the other one, however, was completely knocked loose from the panel and had to be superglued (under the head), to get it to stay in place for bondo. Funny thing is, one of my studs was also loose from the factory and also had to be super-glued down. Then I applied a layer of bondo, sanded, then applied a layer of glaze putty, sanded, primed with 2 coats, painted 2 coats of satin black and called it good. I could have kept obsessing over it and made it totally flat, but I was getting sick of having to do this much work to a $75 "New" control panel. There are still bumps from the bondoed studs that are noticeable in the harsh light or when you rub your hand over the surface, but they aren't as severe a transition as it woulda been if I would have left the stud heads alone. Overall, looks nice, not perfect, time to move on. I'll post a pic of it tonight.
