Multi-Williams control panel cracking repair...possible?
zutton1
Donor 2011, 2018
New York
Ok so the clear outer coating on my CP is cracking is there a way to repair this? I was going to try crazy glue gel but not sure if that is a good idea...I would like something that would hold and dry clear any ideas? Thanks!
Perhaps it's not happening to anyone else.
Am I correct in assuming it is cracking at the bend?
How did you apply the overlay?
Where did you get the overlay?
Darren Harris
Staten Island, New York.
The multi-Williams I picked up has cracking along the bend as well. I will probably just look for a replacement overlay and use the technique of clamping it to the panel before applying it.
