Kyle Dracup
On the multi Switchers for Jamma games how many boards can it Switch between and who sells them or where can i find one. ive seen ones that does two boards but is their ones that do more than two.
+ 1,000,000,000,000,000,000this should be in the general discussion forum...
jammaboards.com is the same one as Yatons as far as I know over at http://www.arcademvs.com/ARCADE_ACESSERIOR.htm
There have been known quality issues with some of those, all fixable, but annoying that you have to. (solder joints, diodes backwards, etc)
And they are known to NOT have the -5v wired, so you will want to remedy that if you plan to run any boards that require it.
