Multi-Game Restarting
danmac360
So the other night I was playing my 60-1 and it restarted itself. I thought it might be a bad power supply, but I checked a few times and it's supplying the proper voltage. This machine is pretty straight forward so I'm assuming it's a board issue. Any ideas on how to troubleshoot this problem?
If you give the machine a solid thump does it reset?
If so, check for loose wires, bad interlock switches, or a bad power supply.
If you have a spare power supply, swap it out and try that 1st.
I have an Assault and Ghost N Goblins that both would reset after gameplay started and as it turned out, it WAS the power supply - readjusted them both and problem went away.
I like setting the +5v to +5.1v.
Good luck!
