MTC 900 Suction cup damage
ckong
Lochem, Gelderland, Netherlands
The connector inside the suction cup of my Hantarex MTC 900 has had its best days (long ago). Some plastic parts are broken (off).
Now I need a new cable, but I guess I have to buy a complete flyback transformer, with cables. I noticed that arcadeshop.com does sell flyback transformers for the Hantarex MTC 900E. Are they exchangeable with the MTC 900?
And what is the difference between a 900 and a 900E?
What kind of grease do I put around the suction cup, can that be just plain grease?
I would say for compatibility look at a manual as the parts break down will give you a part #. If it matches between the two you're good to go.
As far as grease goes - you don;t need to use anything. Clean the surface is all you need to do.
