I had a working Pacman Plus board that I attempted to convert to the 4in1 pac with the older dip-switch method. I followed the directions and triple checked everything. .. but only Ms Pacman would work. I gave up and assumed I had a bad ROM.
I decided to try the menu (souza) based roms instead. It boots and starts the menu. If I select MsPacman, it runs/plays just fine, but if I select Pacman (or pac fast) it immediately crashes and returns to the menu.
Has anyone run across this behavior before?
Thanks in advance
Thanks in advance
