Ms. Pacman Problem
lextek1
Friendswood, Texas
I purchased a standard speed rom to replace a high speed one. Put in the chip and got nothing but a single flashing 1. I re installed the fast rom and it works fine. Also noticed the same flashing 1 when the rom was removed completely. Seems as though the board is not registering the new one. I pressed it in all the way and made sure there were no bent/broken pins and all of the pins line up. The rom is oriented correctly on the board. Got the rom from Mikes Arcade. Could this rom not be programmed? Position 6F
Don
Could be it was mislabeled, didnt verify, bad eprom, bad socket. But yes, the 1 indicated position 6F, they start at 6E which would be rom 0.
A call to Mikes Arcade has a new one coming. Seems they had a few ROM's with this problem last week. Thanks for the help guys.
