Ms pacman help, no sprites
DTAR
Donor 2011, 2019
LOS ANGELES, California
hi,
i got a Ms pacman that shows everything else but the sprites, so no ghosts or ms pacman. i've tested the rams and they are all good. not sure what is the problem.
any idea.
matt
How did you test the RAM?
Do you mean you tested the contents of the eproms?
Show us some clear, focused pics of the game pcb.
I tested the RAM in a RAM tester, i found the issue using mikesarcade site. i'll post if it fixes it.
Look down in row 1/2 around the middle of the board. There are a couple 7489 ram, 74161,74283 and a few others that affect moving sprites. I would start with the counters and ram since they are the most common failure.
