Ms Pacman Hacked Level/ Speed too fast
wmacmonagle
Donor 2012
Rosamond, California
I had gotten the ms pacman cabinet and finds that board as orignially but being hacked level and all levels not look right. it looks like im on banana level and not being on cherry level eventhough it is showing im on cherry level.
Wondered if anyone has tips or letting mek now where to find the parts to convert back to normal as orginially?
PM would be appreciated if you have that part to sell. Thanks
Sounds like you may have the speed-up rom installed. You can buy a regular speed rom from Mike's Arcade, or Bob Roberts and replace it, making the speed of the game revert back to the normal, slow speed.
Unless I misunderstood, which is quite possible!
yes thanks for the tips on speed but the maze and level arent that orginal. It seems hacked also..
i checked at mikesarcade and says they have standard maze chips. i was not sure if that s the part i need?
http://www.mikesarcade.com/cgi-bin/...rades&subcategory=&startlist=30&sku=&listall=
Never seen a hack swap the same levels around. Your board may just have issues that need to be repaired.
William,
I'm sure you're talking about one of the Ms pacs you bought the other day. The only thing I really know about it is there were several games that were the same. I believe they were just a simple ROM hack meaning, you can replace the ROMs that include the mod and it should Make it the way you want it to be. They should have labels on them indicating that they are modified. I don't know this to be fact but I believe that is the case.
Greg
