Ms Pacman hack Monitor deminsion mess up
jmballard5
Georgia
So, I was inside my Ms Pacman (hack) machine messing around, trying to get the sound to work (unrelated problem, I hope that I'm not so concerned with now) and then I looked up at my screen and it was too wide to display all of it. The left, top, and bottom sides are all positioned a little, but the edge of the right side of the screen ends wayout of sight, past where the display ends. Is there any easy thing I can do to fix this? This is the first and only machine I've ever had, and as such I'm pretty much a noob at the arcade machine thing, but it'd really like to get this dimension problem fixed by tonight, since we're throwing a party. Thanks for any help you can give me, here are a few pictures to show you want I'm talking about:
http://i47.tinypic.com/2up8z82.jpg
http://i45.tinypic.com/25iu9hz.jpg
http://i45.tinypic.com/24yp83t.jpg
Looks like something you should be able to adjust back to normal. When you were "messing around" dealing with the sound issue, you didn't happen to adjust any of the pots on the monitor chassis did you?
i just found all the dials and shit that change the settings, i guess i brushed against one and turned it while i was crawling around in there, thanks for your help
