ms pacman cap question
brian77
wichita, Kansas
do all the ms pacman have the same monitors..if so what kit do i need..i looked everywhere for the brand and series number and all i have found says rca. its not at my house or i would take a pic
thanx Brian
You need to take a pic, as most have had the monitors chamged out at some point and time. Not to mention that they came with several different monitors and it was just a luck of the draw at the time thing.
thanx guys.. i found out which one it is.now for question #2 when i start it up it will play fine for 30 seconds to a minute then it starts to scroll and the picture messes up.is there something else i should check while i have it all apart
do you think replacing the caps will fix the screen from messing up when it scrolls. i will try to make a video tomorrow if that helps
its an electrohone(sp?) g07. i can't tell if it humms. it has no sound. trying to fix one thing at a time.i figured i would address the sound issue later
How do you figure out it was a 4600? Didn't see him confirm that yet....
Wrong thread. DOH!
Could have sworn there were 3 pics in this thread earlier today. Two of them with glitched up graphics and one with the monitor almost upside down.
Found it, definitely the wrong thread, sorry for the confusion.
Which direction is it scrolling? If left or right, then it is a vertical hold issue and you should adjust the vertical hold pot on the chassis. if it is scrolling up or down, then it is a horizontal hold issue and you should adjust the horizontal frequency pot on the chassis.
If either slows it down but won't get it to lock, then you need to have a full rebuild done on it. G07's don't usually last long with just a simple cap kit - unless the flyback has been replaced at some point in it's history...
