MunsonRoyE
Hi all! I've been working on getting the Ms. Pacman up and running and I am having an issue with the final 1 AFB fuse blowing on the 5-5-1-1 fuse board. When I turn on the machine I can see the fuse glowing and I gets really hot before it finally pops after a few minutes. Everything works fine while the fuse is active. Once it goes the game still plays, but the monitor gets a wave in it.
The PCB has some burnt edges on it so I thought that might be it. I installed a Pacmend kit and that didn't help.
I have 2 working daugher boards and it still blows with each one.
If I unplug the monitor it still blows.
If I unplug connector from the board the fuse is fine, which leads me to believe there maybe something wrong with the board.
Could this be an issue with the caps on the board or is it more of a chip issue?
