toro1966
Hey guys - anyone have some pics of a Ms. Pac Back Door . I would like pics both on and off the cab if possible. Getting ready to cut one for a resto project and I am having a hard time figuring out the cuts. Thanks!
see if DPtwiz or OU Flight can cut you one..
Thanks, but I have no problem cutting it myself. I just don't have one to match it with and I want to make sure the cuts are correct. I will get a hold of him though and see if he has a diagram or layout. Thanks.
Absolutely perfect! Thanks!You asked for pics, but I think measurements would be a little better.
Below is a pic and also a diagram of the top left corner of a door I have. (Not accounting for 30 years of fluctuating humidity). From that you should be able to figure out the rest.
A) The door is made of 1/2" thick particle board.
B) It is 41" tall and 23-11/16" wide.
C) 5/8" of the bottom is routed down so that there is a 3/8" x 3/8" lip remaining.
D) Each rectangular hole is 5-1/16" x 1-9/16" with rounded corners.
E) Each of the four pairs are separated by 1-3/16".
F) The top left hole is 2-15/16" from the top and 2-13/16" from the left side.
(Just ask if you have any more questions).
Darren Harris
Staten Island, New York.
