Ms. Pac Switcher PSU Install questions
oktobernv
Henderson, Nevada
Greetings all
I'm coverting my Ms. Pacman PSU to a Swticher PSU....
SEE ATTACHED PICS
This is my first switcher "conversion"
I'm a bit confused as to where some of the plugs connect
The "main harness" is obvious......
there are also THREE other "plugs" connected to the switcher
SEE ATTACHED PICS
There are "three" plugs - lets call them "small" "medium" and "large"
Can you let me know where to properly connect these?
Does the "large" one connect near the PCB (see pic #3)
Or does it connect up to the control panel?
Can't seem to find a logical "match" for the other two plugs "small" and "medium"
Many thanks for your help on this.
Thanks for the reply DOk
Starting to make more sense now.
One quandary...
The "large" plug that is attached to my switcher harness is "male"
So not sure how that ties in....
If I follow the leads on the current "original" PSU wiring harness, it seems that if I connect the "large" plug to the "female" 12 pin that resides near the PCB, then that would actually send the power back down to the original PSU and not to the game
Check the pics I posted, does my switcher not have the correct plugs attached?
Is it possible this switcher is not correct for a PAC / MS PAC?
Many thanks,
Rob
