Ms pac reset
Mizzou
Virginia
Asking for someone else...does this maybe sound like a low 5 volts issue? From the sound of it he is describing the opening boot sequence..
"The opening screen ends up a grid of squares and flickers on and off and it won't stay on the opening game board to play it. That's all I describe, sorry....I'm not a technician"
Thoughts?
replace the fuse holders in the bottom of the cabinet there by the 2 transformers and go from there.
the fuse holders get weak and don't grip the fuse tight enough to pass enough electrons through to properly run the game.
probably install new fuses too good luck
