Ms. Pac Man--White Cherry & Marquee Light
turbodrabbit
Maryland
No pun intended, I recently picked up a Ms. Pac Man, and the cherry is white, but the rest of the colors are correct. The strawberry is off white as well. Has anyone had this problem?
I searched around, the marquee light is barely lighting up (just the sides), so I replaced the bulb, but no change. I haven't taken it apart to check the starter, and I have read posts that recommended changing the fuses/cleaning the holders. Any other tips?
Change the FS-2 starter for the marquee light.
As for the white cherries, check 4A or 7F...
I think the board was switched out from a pac plus. I assume the other colors are right, but this is my first Ms. Pac.
Post a screenshot.
I have seen a bad prom display some colors wrong but others right. In your case I think you have pac plus proms.
