Game plays. Black area of screen is white and maze is red. I have pictures for reference. Any clue as to what the issue is would be helpful.
"White background, red maze, blocks behind characters.
5C Removed
5A p14 high"
per https://www.mikesarcade.com/arcade/pactrouble.html
Are the dots still there?
Yeah I read that. But I wish he would have elaborated a little. Does that mean 5C was removed from the board when he got it?. What does that mean? There is a 74LS194 at 5C. Does that mean that 5C is bad and needs replacing?
I would probably shotgun it to swap out 5C with a replacement chip. Otherwise it's a logic probe check to confirm it's passing data through correctly. You could always try taking 5C out to see if anything changes as well. Seems to be a pretty dead-on description of your issue.
Wrong color proms.
Watching this thread..i have the same problem with stand up ms pac. The game played fine then one day i turn it on and it looks almost exactly like yours. Here is my thread on it:
https://forums.arcade-museum.com/showthread.php?t=401178
I see your thread doesn't look like it concluded with a solution. I have the parts to swap in new 74LS194. Try to get to it this week. I will post results.
Any news to report?
It means absolutely nothing because that "guide" is completely worthless.
