ms pac-man running slow and choppy
Alky
Chesterfield, Missouri
I never really dealt with an original ms pac-man before and a guy was asking me to help him figure something out. He said over the phone he wanted to buy this ms pac machine but it was slow so he wanted a speed up chip. I said run it by and ill take a look at it. Well it looks it has a main pcb with a ribbon cable connecting a daughter board and it also has a small board about 4x4" and is plugged into the main board in the middle. I turned it on and it plays very slow and very choppy, also the edge of the screen seems to jump a bit when i move the joystick. I guess my question is where do I start. Im not charging him and am just trying to be nice to guy who wanted to start collecting and this was his first buy. Dunno if it matters but this is in a cocktail as well.
If a filter board is present remove it. (Harness plugs into this board which in return plugs into the PCB).
Inspect the PCB edge connector. Not uncommon for the grounds to burn up. If so you'll need to rebuild the edge connector otherwise clean the edge connector and fire it up.
It looks like pac stops and takes a bite at every little pill. Like a stutter step and the ghosts do it as well. I might just tell the guy sorry I cant do anything. I forgot to mention when he called me he said he had a Pac-Man machins not a Ms. and just needed help installing the speed chip.
