Ms. Pac-Man problems
Atlas100
Illinois
I recently picked up a Ms. Pac-Man machine. Other than a very nice unfaded marquee and bezel, the machine is in pretty rough shape. To be honest, I couldn't believe it powered up at all.
Anyway, when it powers up the screen is very garbled. It looks like it is functioning correctly, but it is garbled. I did a bunch of searches for the last week or so and found screen shots of Ms. Pac Man board problems. After a ton of searching I couldn't find one that matched mine.
I took three screen shots and included them here. They were taken without the flash. The monitor obviously needs a cap kit and some adjustment, but I don't think it is the problem. I am assuming the board has issues, but who knows.
Let me know if you guys can spot the problem or give me some advice on fixing this board. If you need any more pictures I will take them. Thanks for the help!
Looks like a vram addresser problem....
On the bright side, the sprites are being drawn correctly :)
Should a pretty cheap/easy fix.
