I picked up a ms. pacman a few weeks back, and the power switch on the top of the cab wasn't connected. There were two wires running up (i think blue/green), with one attached to the screw holding the power switch in, and one attached to a screw on the speaker. Any chance these are supposed to be attached to the switch itself?
There were then two thicker brown wires running to the coin door and soldered to the tech switch up front, with the connection wrapped in electrical tape. I was thinking maybe these were supposed to be attached to the power switch on top, because there were two red wires that had been cut on the coin door that were hanging loose with the ends taped off.
I cut the brown cables so that I could remove the coin door, and now I'm just looking to get things attached properly in the coin door, as well as getting the power switch up top reconnected. I can take more pictures later if needed, but wondering if anyone can provide any info or pics of the wiring on their coin door switch and the switch on top of the cab.
Thanks!
Here's the two loose wires inside the coin door:
Thanks!
