ms. pac-man monitor adjustment help
owlnonymous
St Petersburg, Florida
Hey Guys,
I have read almost every G07 monitor post on this forum, and I still can't get my monitor right. I have some bleeding red showing around my white and red borders. I would also like to adjust the horizontal and diagonal width, but I'm nervous about getting shocked. Please help!
Thanks,
Patrick
its not that hard and you wont get shocked ,maybe a little jolt but not that bad as long as you dont mess with the monitor flyback.Unplug the machine and look at the chassis there are small adjustments in plane veiw at the bottm of the board (round metal looking tabs)vert ,horizontal,etc.There are also color adjustments on the neck board for red,green,blue.IF you are worried abiut being shocked wear rubber gloves.I am just a newbie myself but have been working on a pacman and just got done with a Ms pacman and its not as hard as you think as long as you research what you want to do and listen to the people on this site .I discharged two monitors and swapped to monitor chassis on both the pac and mspac !!Good luck and have fun!
Some added advice: Don't try and adjust the monitor by reaching around and turning the adjustments. This is a recipe for disaster. Set up a mirror in front of the machine so you can see it from the back or get help from another person. I like the mirror method.
