scottnagle
New Jersey
Can anyone tell me how to fix this issue?
Images at bottom of screen bleed down, while images at top seem fine.
Image1 is at the top of screen - seems fine.
Image2 is at the bottom of screen - bleeding down.
See pics attached.
it may be off some but it is NOT his main issue,
that monitor needs to be color and wight balanced badly.
blue is bleeding threw the black and that will cause his issues.
i would NOT mess with the convergence until it has been capped and then color and wight balanced.
if your local to me i can color and wight balance it for you, you will be amazed how it will make it look.
Peace
Buffett
if you need a cap kit or parts let me know i have them all in stock with top quality caps. if you haven't done a cap kit then do that and color balance and see if the convergence is off enough to worry about, but if you have done a cap kit recently then color balance and see if convergence is off enough to worry about.
Defiantly cap it if you haven't grab a kit from security he's a great seller. I had a sanyo that would bleed colors no matter what I did until I capped it.
