Ms Pac Man cabaret fuses
JoeG
Houston, Texas
Hi everyone
i was testing some boards in my ms pac cabaret and those boards were blowing my fuses.
that made me look to see if i had the correct fuses in there in the first place.
can someone confirm or correct me regarding the bank of four fuses in a ms pac cabaret:
(looking in the back, from left to right)
2amp/250v
1amp/250v
5amp/250v
5amp/250v
This combination works with my good board, but according to a bob roberts diagram posted in another thread, the fuses should be 1a-1a-5a-5a... that combination in my machine blows the 1a fuse farthest to the left with my good board... and the game still works with that fuse blown.
any insight would be appreciated.
thanks
joe g.
houston tx
Two 1A and Two 5A fast blows.
Some boards will play with only one fuse, some wont boot at all. Some will boot and play attract mode and reset when you start a game, all depends on the condition of the boards power supply...mainly caps.
Take out that 2A and put a 1A in. If its blowing the fuse you probably have an issue on the pcb.
