Ms Pac Man blue spray paint (for top) and question about the black
Nutty 5.0
Pennsylvania
I've searched high and low here and the internetz trying to find what color blue for Ms. Pac Man is closest in spray paint. The only thing I found was someone used a blue spray paint from Rustoleum Painter's Touch line but not sure which one. I just want to paint the top and back door.
And, where does the black inside the cabinet (when playing) start and end? I've seen pictures of restorations, etc. but haven't really been able to verify what is correct. Mine has a line at the top of the marquee brackets and is consistent on both sides.
Thanks for any help!
I just went straight up from the back of the marquee bracket on the top, and straight across from the bottom of the CP on the bottom.
Agree, it does look incredible. Thanks for sharing the picture. That's how I'd like to do it because it looks correct but after seeing a bunch of supposedly orginal cabinets on google it looks like mine is correct to be original. I think you swayed me to your way Phet!
i also went straight across from the top of the front panel...but I did the top at an angle to get closer to the original oversprayed look...
Looks awesome vader! I also got pink T molding and looking at yours affirmed my choice. Thanks for sharing.
Are u getting the side art decal? If so...best idea is take a sample of that blue to Lowes and get it paint matched. I did and its pretty much dead on. Used latex semi-gloss. That second pic shows how close a match it is. The front panel is art...the little 1" edge is paint....u can tell how close it is.
Yes, side art decal. Thanks, and yes it is dead on! I was hoping to just spray it rattle can but looks like I'll just pick up a quart and roll it on to the top, back and that little 1" area.
I did the same thing(decals and quart of blue matched to the decals). I decided that the angle I would use would be so that when I was playing the game, I would only see black. If I backed up at all, I could see the black and blue. I think it was pretty darn close to the way it came from the factory.
