bkctonight
Hi all.
My Ms Pac Man machine continues to blow the Line fuse (currently 2 amp) everytime I power my cabinet machine. My on/off switch on top of arcade is good. My kill switch on the inside is good (keeping it in the up position so that the circuit is always connected). But as soon as I place a new 2 amp fuse and plug in the machine (every button and/or switch on the on position), the fuse blows. How much voltage should be running through that fuse? I am pretty sure my fuse amperage is right at 2 amps. I am really stumped here. I have followed the volts using my meter all the way from the ac power cable (wall plug) to the amp clamp and I am reading about 120 volts.
Any help or advice would be great.
Thanks.
Thanks.
