i know i am probably having a brain fart with this, but i was looking at a ms pacman which worked when plugged it but the power switch was non-functional. To me, it seems that someone swapped wires around on the interlock to allow it to function. I originally thought it was a bad power switch but that does not seem to be the issue as it worked the same way when the switch was removed. I believe the interlock in this case is a DPDT.
i was running short on time so I couldnt trace the wires, but the wires dont look hacked (still brown and blue wires on the switch) and the harness looks to have all of the tiny wire ties holding it together so no additional wires are run anywhere.
does anyone have the flow of the interlock for a ms pac?
