Ms Pac Help
How do you have the video wires hooked up? There should be: red, green, blue, ground, sync.
Also, the converter board requires 5VDC to operate.
And make sure your VGA monitor is plugged in the side that has 2 VGA ports.
I have the output of the game PCB going to the 5 pin CGA input, and the monitor is connected to the 1st Output. I'm using a wall wart for the supply voltage.
I have output from the converter board going to the monitor, I tested this by hooking my wii up to the composite input. And I used my scope to make sure there was some kind of signal going into the converter.
