Riptor
Shall I bring you a trade in board to Crabtowne?
I have replacment sync bus cards in stock. Save your old one, if its bad it can be repaired. FYI, TTL chips dont usually burn up in a literal sense. Are you sure thats not just a stain from something getting spilled on it such as soda or mouse piss?
Post a picture
One of the small chips on the board has brown around all of the solder on the back side. If you're looking at the little board while it's installed on the main PCB, it would be the little chip in the upper right corner that appears to be fried.
I've seen this on several boards. Usually that brown stuff is residue from certain types of solder. If that is the only chip that has that stuff on it, it means that the chip you are talking about was replaced by someone (a long time ago).
But yes, I picture will help.
That brown residue under the chip seems to be normal, it shouldn't affect how the chip operates. Though that replacement chip that was installed there could be dead, again. Though earlier in this post you said you kept getting RAM error messages. Are the RAM chips removable? Also, is the garbage on the screen moving/flickering or is it stable?
One last thing. If you have another Pac/Ms. Pac machine. Try passing components between the two boards one at a time (Power up the working board with the Processor from the non-working board, see what happens, do this with ROM's, RAM's, expansion boards, etc..)
The offer is open if you want to bring the board down one day. I will give you a crash course on repairing the pac board.
