ms pac / galaga reunion can i put 60 in 1 in it?
monster kong
California
i have a dedicated upright ms pac man / reunion with 25 inch monitor.
the original board keeps adding credits out of nowhere and random resets into test menu.
can i remove the board and put in a 60 in 1 in there instead since the 60 in 1 board costs less? also, can i play the othr 60 in 1 games?
As long as the reunion is a JAMMA wired cab, yes you can. You should just be able to pull out the old board and plug the new one in. You might want to add a few extra buttons, for the games that require them- or not. Anyway I'm sure someone can chime in to confirm if it is a JAMMA board. You also might be able to look at the board itself, a lot of JAMMA boards are labeled as such.
It should not be a problem. That cabinet is Jamma. You will just pull out your PCB and put in the 60-in-1. Make sure you have the dip switches correct for your monitor and configuration. (arcade monitor) (stand up/upright, one joystick).
Here's the pinout for the upright Reunion cab. Notice where the Galaga Start buttons are wired...
