Ms Pac Drama
If your board had the ABC kit installed, then you likely have problems in your program roms and/or sockets in row 6.
Your only easy option at this point is to wait for your replacement ribbon cable. Looks like your board had the "shortcut repair" I mentioned above. You'll have to let the ABC board run your program code, which is all on the daughter card.
Finally got that ribbon cable in. I changed it and re-tightened everything up good. I had previously re-seated everything also as suggested in this thread. Everything is back up and running :) not sure which thing fixed it but something did...
Also, this game has been rainbowed since I got it. I borrowed a degausser from a fellow KLOV'r and I had it ready to use since it was still appearing with that gradient rainbow effect after the fix. But before i used that I wanted to put in the new muffin fan that I had ready to go because the fan was DOA.
As soon as that fan was plugged in the rainbow effect went away!?!? Coincidence? Was heat inside the cab causing it? Or some buildup of static or something from the fan not working? Or maybe too much electricity was going to the monitor because the fan wasn't getting it? No idea but kinda weird. I gotta admit I was a little disappointed I didn't get to use the force as planned...lol
Thanks for the help with the board everybody!
