On an original Ms Pac Cocktail which control panel is player one? If you are looking from the side facing the coin door, would player one's control panel be on your left or right?
I believe the player one panel is the one with the start buttons on it.
I know that... but I want to know which side of the cocktail table is it usually on? Is it usually to the right or left of the coin door?
1. plug in game
2. turn on game
3. look at screen
4. move body until you are looking at the screen right side up
5. install player 1 control panel on wood in front of you
Cananyone confirm if galaxian is the same?
Thanks jr pac! Way better answer than the first one
(mine runs tetris with no start buttons, a jamma harness installed in a previously empty cab, and the yoke wire connector has been cut and swapped... i got unhacked galaxian cps for it years ago, havent wired it up yet, but always wondered which side should be p1
hence the failure of answer #1)
