Ms Pac Aux Board Possessed by Evil
jlpmauldin
Donor 5 years: 2017-2021
South Carolina
Sorry in advance for another Ms Pac-Man related question...
I have a Ms Pac that shows the static image below when I power up the game.
Steps taken so far:
- Replaced all sockets on Aux board with new ones
- New ribbon cable
- New 40 pin socket on main logic board (where the ribbon cable plugs in)
- Verified all eproms on aux board (U5, U6, and U7). They all checked out at ROMident. *I originally thought these were non-standard hacks. Sorry. Ninja edit fixed*
- Removed and measured both electrolytic capacitors on Aux board: Good
- Removed and measured the 4 ceramic capacitors on Aux board: Good
- Verified all board connections at every pin on every component on the aux board per the schematic. All good. No broken (or bridged) connections.
I have removed the Z80 processor and the ribbon cable and plugged the processor into the
main logic board. As expected, the game comes up as playable Pac-Man with some sprite weirdness.
I have taken a known working aux board, plugged it into the new ribbon cable, and the game comes up and plays normally.
I have swapped all 8 chips from the bad aux board with the 8 chips from the good aux board. The good aux board still boots up normally, the bad board still refuses to do anything except show the same static image.
I looked at the supply voltage on the board with my scope. I see a stable 5V (4.94V as measured with my DVM).
I'm pretty much out of ideas. Before I perform an exorcism (or just admit defeat, buy another board and get on with my life), has anyone seen this problem? Any ideas? Thanks!
uc
https://drive.google.com/file/d/1-TlithBMdS5C3EfzF7g2Eoda06sCtngQ/view?usp=sharing
the 4-in-1 is easy enough to do. Plus it give you both games at fast and slow, freeplay with attract and high score save!
if you need a known good aux board I"m pretty sure I have a few spares.
$25.00 shipped to USA
sorry my apologies, I was not able to validate any of my aux boards as my test ms. pacman board has decided to stop working.
-brian
Thanks to everyone for the interest and helpful comments.
-brian
No worries! Already got other parts on the way. By the time this project is over, I'll have lots of spare parts.
I think I may use some of the spares to try the 4 in 1 hack. Time permitting so we'll see. I've got a whole other Ms Pac to restore after this one... and several other games... so many.
Still kinda bummed I never figured out the problem with the first aux board. I may try to replace the ribbon cable socket again, just in case I messed up an old trace or something.
most likely a bad ribbon cable, as the CPU is on the aux board.
I don't know for 100% certain where replacements can be obtained, but as noted in other posts above, you have a lot of different options.
I hear that Catholic priests are good for things like that?
What do you mean "speed up" hacks on the daughterboard? The standard speedup hack is done on the motherboard at 6F and the "hot pursuit" full-speed-up versions don't use the daughterboard. The only daughterboard mod I know of is the U7 for Ms Pac Attack mazes.
If you have some kind of bootleg speedup it may be that they also require a matching custom row 6 and don't match up.
I'd for sure replace/reburn the U5/U6/U7 with stock just to at least rule that out :)
Here is the ROM ident info for the ROMS that were installed:
uc
https://drive.google.com/file/d/17kHmeqpjo7VW6W2-j0O61ezl8zi0nEpW/view?usp=sharing
I guess I misread this information originally. I see now that this probably just means the ROMS could work with the speed up hack, not that they have necessarily been altered themselves.
When I install these on the good aux board, the game works and Ms Pac goes really super fast. Also, coining up instantly starts a 2 player game (no chance to press 1UP or 2UP).
Maybe I should burn a completely clean ROM set and try it. Not sure if I have a spare 2716 around at the moment. Thanks for the help!
