action53
When you let go of the stick, she moves down all by herself, all other directions work fine
I confirmed the contacts aren't touching, there's no shorts in the cp harness and the stick goes to center when you let go of it.
Testing between the two wires on each stick the left, right and up has 1.08k ohms when the contacts aren't touching and 0 when they are. Down is the odd man out, 240 ohms when the contacts aren't touching and 0 when they are.
Changed out the LS367 at 8e because that's the one that handles p1 controls according to the schematics, no change. Tested RM8 and all the pins read 1k ohms except for pin 9, it read 240 ohms so I replaced it, still no change. The RM8 I removed tested 1k ohms on all pins out of circuit and the new RM8 that tested good before I put it in tested the same as the old one in circuit
Any ideas?
Any ideas?
