Mr & Mrs Pacman
alaird
Louisiana
I recently replaced the main pcb on my Mr & Mrs Pacman. The game now at least comes on and I can get into the test mode. In test mode, it tells me that all of the solenoids are bad.
I checked the fuses under the playfield and found that the one near the right bottom flipper was blown. I replaced it and tried the test mode again. I got the same error codes and checked under the playfield and that fuse was blown again.
Any advise?
fuse
sounds like you may have a bad coil or a bad transistor. when you turn the machine on listen for a coil kicking on. if a transistor goes bad it can lock on a coil at power up until it blows a fuse. if you have a bad coil it could also blow the use on power up. check these things first. if you have a coil powering up when you turn it on look in the manual and it will tell you what transistor powers that coil. pm me if you have more questions. good luck!
