keithsarcade
Mr. & Mrs. Pac-Man Pinball Left Slingshot help...
Well I replaced a bad coil on the left slingshot. The old was was blowing the solenoid protection fuse (under the playfield) and eventually smoked and melted until it was rendered useless. New coil seems to work, but is still blowing that same fuse.
I have been all over the Solenoid driver PCB and all solder joints have been repaired and look fine. Wiring looks fine too, I cant find a short anywhere.
The game will work fine as long as the wires are cut from the left slingshot coil. Only now theres no left slingshot (obviously) as well as the return for the 4th left drop target which I guess is somehow linked to the left slingshot (both use an orange/red wire).
Any ideas?
Any ideas?
