Mr. Do's Castle and JROK HSS...
channelmanic
Donor 3 years: 2011-2013
Texas
Installed the JROK code and the DS1220 NVRAM chip on a Mr. Do's Castle for a forum member and ran into a problem...
The board wouldn't boot with the DS1220 installed. It would boot when probing the lower address pins with my logic probe... otherwise it would sit stuck in watchdog.
Installed a 9 pin 470 ohm SIP resistor pack on the first 8 address lines and tied the 9th pin to +5v and the board boots every time.
Just thought I'd pass that along if you run into troubles with installing that.
RJ
