Moving a 720 - possible to break it down?
kspiff
Humble, Texas
I'd really like to get my 720 moved over to the pad, but its strange shape and extreme weight have me concerned that I might eff up the incredibly time consuming resto job I did on it.
Is it possible to unscrew the monitor/marquee piece and separate it into two for moving? Or did they staple and glue the hell out of it? Anyone tried?
Guess I may just be stuck renting a truck with a lift gate... or maybe having a friend help move it so I can slide it into the truck strapped to a large appliance dolly. :/
Can't you just pull the monitor out to get rid of some of the weight?
After moving one in for the Seattle show a couple of years ago, I'd say that's one of the more awkwark cabs to move due to it's overall weight, shape, and top-heaviness.
I don't believe you can take the cabinet apart any. Looks like your best solution to the weight is to remove the monitor glass, bezel, and monitor. I haven't removed the monitor from mine, but I'd bet that's a 2 man job, unless you're willing to risk f'ing up the cabinet.
That would help a lot, yes, but the machine is still heavier than a mofo.
Besides, the point of breaking it down would primarily be to keep the back angle from getting torn up if I slide it into my truck on its back. Even with multiple people and the monitor out I can't see me getting it loaded into the truck upright.
Such an odd cab design. If only the back were flat and didn't have a bit of wood jutting out past the molded edges I wouldn't need to worry about it. :(
I'm also fortunate enough to have a hydraulic crane on the back of my truck, but when I picture myself trying to hoist it up with straps running under the top half I envision potentially disastrous results (like the weight of the bottom half ripping it into two pieces).
@joeycuda: You're right about that for the most part. I got it in solo previously, but it was a bear and I was honestly more muscular back then.
I'm sure I could lift it fine, but with the sharp edges on the monitor frames, I've scratched stuff putting a 19" in..
Once again the odd cabinet design throws a curve ball on that one. The control panel sticks out so far that to get it in without scratching a bunch of stuff up requires you not only to lift the monitor, but support the weight with your arms extended in front of you a good bit.
Maybe not as bad as I'm remembering it, but still a pita.
ive taken the head off of mine when i restored it.. it is stapled and glued to the base.. you can get it apart, just gotta do it very gingerly.. if your just moving it, i wouldnt take that route..
I'd rent a bigger truck or something to move it after it was restored. I wouldn't want to put it on its back or anything...too big of a risk. Know anyone with a forklift?
Even removing the monitor makes it seem like it weighs the same as if you didn't
I have 6 heavy duty 3" casters on the bottom of mine. That thing is so heavy and awkward that getting it into my front door was a nightmare, even though I only had to get it over about a 4" bump for the threshold. I had to strap it to a furniture dolly to help pop it over. Also, it BARELY fits through a doorway, so it's difficult to not damage it.
Ugh. On second thought maybe I will wrap it up, toss it in a corner, and leave it be until I get into a house (if my mother will let me since it's in her garage). My apartment does have a pretty shitty entryway so it would get damaged.
I'm thinking with a collection the size I've got now I ought to just get a truck with 25-50K on it and install a liftgate. Probably ought to do that *before* I bother looking for a house, too.
But then again if I get a truck I might as well sell my Caddy. Which I don't want to put the money into to fix up (not worth it for the return) and don't have the time to sell.
Meh. Maybe I will just get a house, rent a truck with a liftgate for a few days to move with, save up some more money, and then revisit the desire to buy the truck later. That would probably be the most sensible sequence of events.
