***** MOVED!!! Freeplay buttons - Wrong Forum
Jabristor
Donor 2015, 2021
St Augustine, Florida
If you are looking for a Free Play solution for your games. Here is what we use at the Barn.
Easy Freeplay Buttons
These are extremely simple to install. You simply clip them on, run the button around to the front of your door, and VOILA ... Free Play.
There are two options for the buttons
Magnetic - These are in no way permanent.
3M double-sided tape - More permanent.
Pricing is:
1-$10
5-$45
10-$70
20-$100
$8 shipping (tracked and insured) for up to 10 (USA)
Let me know if you need some.
100 of each style in stock
3-wire Freeplay buttons
3-Wire Freeplay Buttons
These are for games like Gottlieb Frogs that have 3 wires on the coin switch.
These also work for games that run the coin counter ground through the coin switch or games that run higher voltage and/or current than the standard TTL signal through the coin switches.
This version uses two coin cells to power a relay when the button is pushed.
Like the other version they are clip-on
Pricing is:
$20 each (Includes two coin cells needed to run)
$8 shipping (tracked and insured) for up to 5 (USA)
These are made to order
Are these used or something? If they're new, they're in the wrong section. I believe they should be posted in:
Trading: New Products, Mods and Services
