Mouse trap Dog/Bird sound
Klumpy
Donor 2011, 2014
San Francisco, California
Any idea on why the dog and bird wont make any sounds? I know i have about three volume controls, but does not seem to get the dog to bark...
Call the dog whisperer?
There are four audio knobs..the dog volume is the upper right volume..lower right volume is music.far left is special effects volume and inner left is master volume..the board does an audio test and will isolate problem chips..you might have a bad sound chip but if just those sounds are missing I'm betting bad pot or volume isn't turned up enough..check the back for broken pots too.. Look at this manual on page 6-8 should help you out.
http://www.arcade-museum.com/manuals-videogames/M/mousetrap.pdf
Brilliant - Dont know why I couldnt see that volume pot earlier. I guess it helps to step away for a bit. Thank you!
