Wolfinator
I'm sure some of you have done it....any tips on how to get a G07 in there in the vertical position?
It won't sound very good, either.
I got all that covered, just wondering about mounting it in place!
Well, did you see what happens when you try sticking it in there? Does it line up?!?! I have seen DKs with Vision Pros in them, I bet the bolt pattern is somewhat normal.
use all the standard Nintendo mounting brackets and you will be fine with a vertical frame mounted monitor.
