You are using an out of date browser. It may not display this or other websites correctly. You should upgrade or use an alternative browser.
Museum of the Game® & International Arcade Museum® Forums
Hi Guys, does anyone know if the B&W Raster Motorola chassis XM-501 and XM-701 can be interchanged on a machine?? As far as i know they are virtually identical chassis but the 501 is meant for the smaller 19' Monitor and the 701 is meant for a 23' Monitor. I've got a Biplane machine with a 501 that has a busted HV Rectifier Diode and i was wanting to possibly swap out with the 701 from my Atari Le Mans machine. I couldn't find any reference to anyone doing this so wanted to check first before just swapping and hoping for the best
On the other hand if anyone knows where you can get a replacement HV Diode for a Motorola chassis that would be great too. I had a look around and there only seems to be a replacement for Electrohome and Wells Gardner chassis.
Cheers!!
