mortal kombat question
You can BUT!
You will need the MKII sound board, ribbon cable and the interconnect cable. Otherwise no sound.
When you swap over you need to swap not only the JAMMA harness but the JAMMA+ Harness (more often referred to as the Kick Harness).
It is a fairly simple process, just make sure you get the pinouts right when swapping otherwise your LK, LP, RUN buttons will be off.
If you get time I would love to see a vid of you multi mk set up and how you swap em out. I'm on the verge of grabbing a umk3 dedicated but love 2. Spent lots at the aladins castle. As a kid. Fyi have you seen the new mk coming out for consoles?
